با سلام ، من برای کپچر گرفتن با خطای زیر روبرو شدم ، و این مطلب را در اینترنت پیدا کردم ، ولی دقیقا نمیدوتم این کامند را چجوری بزنم :
From a command prompt, type 'dism /mount-wim /wimfile: /mountdir:C:\MountDir /index:1' and press enter. (Checking you have a directory present on the relevant drive for your .wim file first).
در صورت ممکن راهنمایی کنید ، تشکر
This happened when trying to capture an image using a Server 2012R2 boot image, more specifically, error message "0xc000000f".Here's how to fix it: From a command prompt, type 'dism /mount-wim /wimfile: /mountdir:C:\MountDir /index:1' and press enter. (Checking you have a directory present on the relevant drive for your .wim file first). *Note - C:\RemoteInstall\Boot\x64\Images\YOURIMAGE.wim is a variable and specific to where your capture image is saved.Once this has been mounted,in the same window you will need to type 'dism /unmount-wim /mountdir:C:\MountDir /commit'. If you're more comfortable with a GUI, check out this handy tool http://dismgui.codeplex.com (.net 3.5 framework required prior to installation).
