در توسینسو تدریس کنید
و
با دانش خود درآمد کسب کنید
سعید روحانی
خطای سرویس در سرور
دوستان نظری در مورد راه حل این مشکل من دارند
سرور 2012R2
AD - DHCP - DNS - WINS
روی این سیستم نصبه
+ System
- Provider
[ Name] VSS
- EventID 8193
[ Qualifiers] 0
Level 2
Task 0
Keywords 0x80000000000000
- TimeCreated
[ SystemTime] 2015-01-20T06:23:29.000000000Z
EventRecordID 2174
Channel Application
Computer PDC.saeed.ir
Security
- EventData
RegOpenKeyExW(-2147483646,SYSTEM\CurrentControlSet\Services\VSS\Diag,...)
0x80070005, Access is denied.
Operation: Initializing Writer Context: Writer Class Id: {f08c1483-8407-4a26-8c26-6c267a629741} Writer Name: WINS Jet Writer Writer Instance ID: {8783fcb0-11c3-426a-aad8-40bd53929bc9}
2D20436F64653A20524547524547534330303030303135362D2043616C6C3A20524547524547534330303030303132392D205049443A202030303030313834342D205449443A202030303030303830342D20434D443A2020433A5C57696E646F77735C53797374656D33325C77696E732E657865202020202D20557365723A204E616D653A204E5420415554484F524954595C4C4F43414C20534552564943452C205349443A532D312D352D31392020
Binary data:
In Words
0000: 6F43202D 203A6564 52474552 43534745
0010: 30303030 36353130 6143202D 203A6C6C
0020: 52474552 43534745 30303030 39323130
0030: 4950202D 20203A44 30303030 34343831
0040: 4954202D 20203A44 30303030 34303830
0050: 4D43202D 20203A44 575C3A43 6F646E69
0060: 535C7377 65747379 5C32336D 736E6977
0070: 6578652E 20202020 7355202D 203A7265
0080: 656D614E 544E203A 54554120 49524F48
0090: 4C5C5954 4C41434F 52455320 45434956
00a0: 4953202C 2D533A44 2D352D31 20203931
In Bytes
0000: 2D 20 43 6F 64 65 3A 20 - Code:
0008: 52 45 47 52 45 47 53 43 REGREGSC
0010: 30 30 30 30 30 31 35 36 00000156
0018: 2D 20 43 61 6C 6C 3A 20 - Call:
0020: 52 45 47 52 45 47 53 43 REGREGSC
0028: 30 30 30 30 30 31 32 39 00000129
0030: 2D 20 50 49 44 3A 20 20 - PID:
0038: 30 30 30 30 31 38 34 34 00001844
0040: 2D 20 54 49 44 3A 20 20 - TID:
0048: 30 30 30 30 30 38 30 34 00000804
0050: 2D 20 43 4D 44 3A 20 20 - CMD:
0058: 43 3A 5C 57 69 6E 64 6F C:\Windo
0060: 77 73 5C 53 79 73 74 65 ws\Syste
0068: 6D 33 32 5C 77 69 6E 73 m32\wins
0070: 2E 65 78 65 20 20 20 20 .exe
0078: 2D 20 55 73 65 72 3A 20 - User:
0080: 4E 61 6D 65 3A 20 4E 54 Name: NT
0088: 20 41 55 54 48 4F 52 49 AUTHORI
0090: 54 59 5C 4C 4F 43 41 4C TY\LOCAL
0098: 20 53 45 52 56 49 43 45 SERVICE
00a0: 2C 20 53 49 44 3A 53 2D , SID:S-
00a8: 31 2D 35 2D 31 39 20 20 1-5-19
لذت یادگیری با توسینسو
فرهاد خانلری
با توجه به اینکه شماره Event هاتو میدونی ، میتونی توسط لینک زیر اقدام کنی به اینکه چه اتفاقی برای سیستمت افتاده
خداوند برکتے عظیم به نام "زندگے" به تو بخشیده است . تو چه چیزے به او تقدیم می کنے ؟ هر روز چیــزے هر چند کوچک به او تقدیم کن ، مقداری عشق به مخلوقاتش . . .
سعید روحانی
مهندس من این رو نگاه کردم ولی اصلا نفهمیدم چطور باید حلش کنم
دلتنگ خودم هستم
فرهاد خانلری
شماره Event هات رو باید در سایت مذکور وارد کنی تا بهت بگه داستان چیه فقط اینکه من زیاد متوجه منظور شما در سوالتون نمیشم یعنی بسیار گنگ هست برام که این سرور چطور پیغام میده و پیغام میده چی میشه آیا شبکه غیر فعال میشه آیا سرویس ها از کار می افتن
کلی ارور نوشتید بهتر بود از اررور مربوطه تصویر میگرفتید تا بشه بهتر بررسی کرد.
سعید روحانی
مهندس عزیز ممنون از پاسخگوییتان
وقتی این خطا تو شبکه میفته تمام سرویس های شبکه از کار میفته و باید حتما سرور رو مجدد ریست کرد تا بشه کار کرد
جالبی این مشکل این هست که این اتفاق هر یک ساعتی که هیچ در خواستی به سرور نرسه و سرور بیکار باشه اتفاق میفته
این ارور فقط یک خطا هست نه چندین خطا که من دقیقا متن خطا در event ویندوز رو به اینجا کپی کردم
من فقط میخوام بدونم چطور میشه این خطا رو رفع کرد
دلتنگ خودم هستم
فرهاد خانلری
وقتی ایت خطا میاد از خود خطا عکس بفرستید ببینیم
ضمناً بگید چه مواقعی بیشتر این اتفاق میافته با اون خطاهایی که دادی و من در Event آی دی شما دیدم و در سایت www.eventid.net دیدم خودشون گفتن ممکنه از سه جا این Event ID: 8193 اتفاق بیوفته که به ترتیب میگم
اگر Vmware دارید و سرور روی VM نصب شده احتمالاً VM خراب شده یا Stop شده
گفته شده اگر ایراد از System Restore باشه فایل زیر آسیب دیده
C:\Windows\system32\svchost.exe -k netsvcs; Descripton = Windows Update; Hr = 0x80070422).
گفته شده ممکنه این اررور از Volume Shadow Copy Service باشه
سعید روحانی
ویندوز روی ESXI 5.5 نصبه
بیشتر شب ها این اتفاق میفته که هیچ کاربری به سرور هیچ درخواستی نمیده
من از این سه تا مورد رو چطور میتونم چک کنم؟
عکس هم فرستادم
وب سایت توسینسو
دلتنگ خودم هستم
فرهاد خانلری
دوست عزیز دقیقاً لینکی که معرفی کردم www.eventid.net همین Error رو معرفی کرده و توضیحاتی هم در موردش داده لینک زیر رو ببین
حالا توضیح داده چرا این اتفاق افتاده و راه حل هایی هم توصیه کرده حالا خودت باید بخونی و انجام بدی مثلاً یکی از اونا اینه که به ادرس زیر در رجستری بری و مجوز دسترسی یا permission بهش بدی تا Access is denied نده
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\VSS registry key
موفق باشید.
از سرتاسر توسینسو
تنظیمات حریم خصوصی
تائید صرفنظر
تو می تونی بهترین نتیجه رو تضمینی با بهترین های ایران بدست بیاری ، پس مقایسه کن و بعد خرید کن : فقط توی جشنواره تابستانه می تونی امروز ارزونتر از فردا خرید کنی ....
