یک میکروتیک روی esxi راه اندازی کردم . متاسفانه بعد از اینکه سرور به دلایل فنی ( مشکل برق شرکت ) خاموش شد میکروتیک بالا نمی آید و پیغام خطا می دهد :
Failed to power on virtual machine NTP-Server. File system specific implementation of LookupAndOpen[file] failed Click here for more details.
Power On VM Key haTask-16-vim.VirtualMachine.powerOn-152078645 Description Power On this virtual machine Virtual machine: NTP-Server State Failed - File system specific implementation of LookupAndOpen[file] failed Errors File system specific implementation of LookupAndOpen[file] failed File system specific implementation of LookupAndOpen[file] failed File system specific implementation of LookupAndOpen[file] failed File system specific implementation of LookupAndOpen[file] failed File system specific implementation of LookupAndOpen[file] failed File system specific implementation of LookupAndOpen[file] failed Object type requires hosted I/O Cannot open the disk '/vmfs/volumes/5d59f1ac-31591212-96dd-2c768a530e3c/NTP-Server/chr-6.44.5.vmdk' or one of the snapshot disks it depends on. Module 'Disk' power on failed. Failed to start the virtual machine.
