علیرضا باقری
میل سرور mdaemon و ارسال نشدن ایمیل ها
سلام خدمت دوستان
از میل سرور mdaemon استفاده میکنم
بعضی از ایمیل ها ارسال نمیشه مخصوصا ایمیل های خارج از کشور
ip سرور رو هم تو سایت mxtoolbox که سرچ میزنم تو هیچ سایتی داخل بلک لیست نیست
این ایمیل برگشت داده شده در جواب
= Greetings from the MDaemon mail system at beheshtian.com =
The following message:
Session-ID: 151081 (specific to this delivery attempt)
Queue-ID: pd35000001063.msg
Message-ID: D0F20A634D9E4282A6EEF17E4B112378@BES.com
could not be delivered to the following recipient(s):
customer@safit.us (unrecoverable error)
despite one or more unsuccessful attempts to do so.
No further delivery attempts will be made and the message has been removed from the queue.
The original message headers may follow at the end of this report. For information on DSN messages see http://www.altn.comdsn.
Please quote the Queue-ID, Session-ID, and Message-ID found above in any inquiries regarding this message.
= Session Transcript =
Session 151081; child 0001
Parsing message <xxxxxxxxxxxxxxxxxxxxxxxx\pd35000001063.msg>
* To: customer@safit.us
* Subject: Fw: steel midsole
* Size (bytes): 14814
* Message-ID: <D0F20A634D9E4282A6EEF17E4B112378@BES.com>
Resolving MX record for safit.us (DNS Server: 192.168.10.21)...
* DNS: 10 second wait for DNS response exceeded (DNS Server: 192.168.10.21)
Resolving MX record for safit.us (DNS Server: 8.8.8.8)...
* P=000 S=000 D=safit.us TTL=(359) MX=[safit-us.mail.protection.outlook.com]
Attempting SMTP connection to safit-us.mail.protection.outlook.com
Resolving A record for safit-us.mail.protection.outlook.com (DNS Server: 8.8.8.8)...
* D=safit-us.mail.protection.outlook.com TTL=(0) A=[213.199.180.138]
* D=safit-us.mail.protection.outlook.com TTL=(0) A=[213.199.180.170]
Randomly picked 213.199.180.138 from list of possible hosts
Attempting SMTP connection to 213.199.180.138:25
Waiting for socket connection...
* Connection established 192.168.10.40:62196 --> 213.199.180.138:25
Waiting for protocol to start...
<-- 220 AM5EUR02FT004.mail.protection.outlook.com Microsoft ESMTP MAIL Service ready at Mon, 19 Nov 2018 08:37:18 +0000
--> EHLO x.com
<-- 250-AM5EUR02FT004.mail.protection.outlook.com Hello [x.1x.x.x6]
<-- 250-SIZE 157286400
<-- 250-PIPELINING
<-- 250-DSN
<-- 250-ENHANCEDSTATUSCODES
<-- 250-STARTTLS
<-- 250-8BITMIME
<-- 250-BINARYMIME
<-- 250-CHUNKING
<-- 250 SMTPUTF8
--> STARTTLS
<-- 220 2.0.0 SMTP server ready
SSL negotiation successful (TLS 1.2, 384 bit key exchange, 256 bit AES encryption)
SSL certificate is valid (matches safit-us.mail.protection.outlook.com and is signed by recognized CA)
--> EHLO x.com
<-- 250-AM5EUR02FT004.mail.protection.outlook.com Hello [79.x.50.x]
<-- 250-PIPELINING
<-- 250-DSN
<-- 250-8BITMIME
<-- 250-BINARYMIME
<-- 250-CHUNKING
<-- 250 SMTPUTF8
--> MAIL From:<info@x.com> SIZE=14814
<-- 250 2.1.0 Sender OK
--> RCPT To:<customer@safit.us>
<-- 550 5.7.606 Access denied, banned sending IP [x.127.x.186]. To request removal from this list please visit https://sender.office.com and follow the directions. For more information please go to http:go.microsoft.comfwlink/?LinkID=526655 (AS16012609) [AM5EUR02FT004.eop-EUR02.prod.protection.outlook.com]
--> QUIT
= End Transcript =
لذت یادگیری با توسینسو
سلام ، ببینید تو هاست تون MX رکورد اضافه شده ؟
روی روتر پورت 25 رو Forward کردین ؟
از دامین تون Ping دارید ؟
اسم دامین تون رو میشه بگین تا بهتر بتونیم چک کنیم ؟
از MDaemon نمیتونید ارسال کنید ایمیل رو درسته ؟ لاگ های SMTP Out رو هم چک کنید.
AMIRHOSSEIN KARIMPOUR
سلام بعضی از ایمیل ها ارسال نمیشه
رکورد mx و بقیه رکورد ها رو ساختم بعضی از ایمیل ها ارسال نمیشه
بله پورت ها رو فوروارد کردم
دامین رو هم پینگ دارم
بله با mdaemon نمیشه
احتمال داره IP میل سروری که میخواید بهش ایمیل بزنید رفته توی Blacklist.
دامین تون ir هست com ؟
.com
آخه با gmail به همون آدرس میل میزنم میرسه به دستش ولی با دامین خودم مشکل وجود داره
آدرسش رو هم چک کردم تو بلک لیست نیست
213.199.180.138
213.199.180.170
احتمال داره که IP شما تو Blacklist میل سرور 213.199.180.138 یا 213.199.180.170 قرار گرفته باشه و در Blacklist عمومی قرار نگرفته باشه. رکورد PTR ساختید برای میل سرورتون ؟
بله رکورد ptr هم از طرف isp ساختم
reverse lookup برای ip شما ایجاد نشده.
اگر از ip ذکر شده nslookup بگیرید باید دامین شما رو برگردونه ، که اینطور نیست.
از مالک ip باید درخواست کنید تا در ripe تنظیمات رو انجام بده و در dns سرور هم ptr را ایجاد کنید.
mojtabashams.ir
علی آقامیری
جواب شما تو خط های آخر Log هستش. برید به آدرسی که داده و ببینید چرا Access Denied داده.
ظاهرا که یک سیستم Anti Span هستش که باید IP تون رو از اون لیست بیارید بیرون.
https://sender.office.com/
جناب شمس برای ip خودم رکورد ptr ایجاد کردم این ip سمت مقابل هست
مهندس آقامیری همیشه به پیغام ها توجه میکنم رفتم به این آدرس https://sender.office.com/ ولی میگه یه اکانت از میل سرور خودتون رو وارد کنید تا مراحل پیش بره
ولی هیچ ایمیلی از این سایت برای Confirm email address به دست من نمیرسه..
علی آقامیری
به هر حال مشکلتون به دست این سایت حل میشه ، یه کاریش باید بکنید !
من با IP خودم امتحان کردم :
1- خیلی هم الزامی نیست که آدرس ایمیل سرور خودتون باشه ، با gmail امتحان کنید ببینید کار می کنه ؟
2- ببینید Junk نشده ، ایمیلش برای من زیر 30 ثانیه اومد.
تنظیمات حریم خصوصی
تائید صرفنظر
تو می تونی بهترین نتیجه رو تضمینی با بهترین های ایران بدست بیاری ، پس مقایسه کن و بعد خرید کن : فقط توی جشنواره بهاره می تونی امروز ارزونتر از فردا خرید کنی ....
